HELP WITH 02 SENSOR
Old Apr 13, 2002 | 06:34 AM
TERRY's Avatar
Default HELP WITH 02 SENSOR
NEED SOME HELP. had slp l/t headers installed yesterday. after driving 10 miles, ses light came on. used the obdII and it showed a PO140. 02 SENSOR CIRCUIT NO ACTIVITY. BANK ONE SENSOR 2.am i correct that this is the one on the drivers side and behind the cat?? also what to do to fix it???thanks much for any help,ideas,infor.
Old Apr 13, 2002 | 10:55 AM
Ragtop 99's Avatar
Default Re: HELP WITH 02 SENSOR
double check that your wiring connection is good, especially if you used extensions.
Then swap the sides and see if the problem jumps to the other side.
Old Apr 13, 2002 | 02:32 PM
TERRY's Avatar
THANKS I'LL GIVE IT A TRY.....
Old Jun 10, 2002 | 04:36 PM
Viper's Avatar
What happened with this?
I just got Po140 and Po160, both O2 problems.
Old Jun 10, 2002 | 06:38 PM
TERRY's Avatar
TRIED CLEANING IT ECT,ECT. REPLACED IT AND NO FUTHER LIGHTS OR PROBLEMS.
