Descreened MAF ???
Old Apr 13, 2002 | 06:34 AM
BudmanY2KTA's Avatar
Default Descreened MAF ???
In LS1 Edit,how much did you change the FlowGm/sec table to compensate for the 100cfm increase.I'm getting low speed surging and have been trying to reduce it.
Thanks Rich.
Old Apr 13, 2002 | 09:04 AM
Ragtop 99's Avatar
Default Re: Descreened MAF ???
How much did your LTRIMs change as a result of the swap? I would use that percentage.
Old Apr 14, 2002 | 12:23 AM
I removed the screen about 6 months ago and used the MAFT to tune it. I just installed a cam and heads with SVO 30#. I rescaled the injectors and I would like to adjust the Maf.What CFM does a stock MAF flow,and could I just add or subtract the % of change to the table? Or am I wasting my time and just tune using my Ltrim values.
Rich
<small>[ April 13, 2002, 12:28 PM: Message edited by: BudmanY2KTA ]</small>
Old Apr 14, 2002 | 07:31 AM
Ragtop 99's Avatar
I'd tune based upon the LTRIMs and they may be fine w/o doing anything; you need to go measure them. Don't forget an accross the table change in MAF rate will also effect the WOT A/F.
Old Apr 14, 2002 | 08:04 AM
TA/30th 1002's Avatar
How did you come up with the 100cfm increase figure by descreening the MAF?
Wich intake do you have?
just a little curious for now...
Thanks ...... 1002
Old Apr 14, 2002 | 10:38 AM
I found it while doing a search on the MAF. I'm using the LS6 intake.
Old Apr 15, 2002 | 12:53 AM
Thanks Budman . . . . . 1002
