ls1 Edit ?
Old Apr 14, 2002 | 06:31 PM
99taws6's Avatar
Default ls1 Edit ?
I am looking at getting LS1 Edit. I have a 99 Trans Am WS6 (M6). I have full bolt-ons, TR224 cam and a NX wet kit. I was looking at getting a MAFT (to do the A/F), getting a Hypertech to do the gears (plan on getting 3.73's), and adjusting the limiter for the cam. I also want to get rid of the O2 Simms, EGR and change the fan temp. I would also like to get rid of the VATS. Do you think with just those few changes for now, it would benefit me to get the LS1Edit. I know $$ wise it will be better, but can I just start out simple like that and be ok? Thanks...George
Old Apr 15, 2002 | 12:38 AM
Team ZR-1's Avatar
Default Re: ls1 Edit ?
Sure you can make as few or many changes as you like and always can make more changes as you get ramped up in understanding on how to do a good performance tune.
I would add to your 1st changes to jackup the max torwue value of 350 ft/lbs that GM uses to prevent less torquw management sucking power down when your launching or hard shifting.
