Hesitation and loss of power
Old Dec 23, 2005 | 06:03 PM
Evo98z's Avatar
Default Hesitation and loss of power
Alright i took my car out the other day, and i was driving it and it started to hesitate and ran a little funny. If i pressed the gas it seemed as if it was stuttering like if it was running on 7 cylinders or somthing. When i stoped at a light it seemed to be running a little high like 200 or 300 rpm. When i would get on it or just accelerate it seemed low on power. After driving it for awhile to see if i could find out what was wrong with it, the SES light came on and started blinking. I was close to home so i started back and the SES light would blink then go off for like 2min then start blinking again. I checked to see if any wires or anything was burnt but nothing seemed to be burned
Any clue to what it might be? Thanks
Old Dec 23, 2005 | 07:09 PM
05GTOtennessee's Avatar
Pull the valve covers and check for a broken valve spring.
Old Dec 24, 2005 | 01:47 AM
Evo98z's Avatar
Yea i thought about that because i broke a valve spring months back, but it was a little noisey it was making a metal to metal sound when i broke the first one. I will pull the valve covers tomarrow and check it out. Any other suggestions?
Thanks
Old Dec 24, 2005 | 02:36 AM
'Trust''s Avatar
If you broke a valve spring a couple of months ago im willing to be its the same thing, good luck and keep us updated.
Old Dec 24, 2005 | 08:05 AM
Bad30th's Avatar
Blinking SES = misfires, definately check the springs if you have already had one break and didn't replace the rest. Take a look a the plugs/wires while you're in there too.
Rob (Bad30th)
Old Dec 24, 2005 | 08:07 AM
Lady Redhawk's Avatar
From: sojourning....looking for my city whose builder and maker is God.
If you have a scanner, see if your ltrims are pegged at 25. Bad 02s will cause that to happen. If you have recently used top end cleaner or lead race gas, it can ruin your 02s or at least make them so dirty the don't read correctly. When you get on the gas the hesitation gets worse and you can feel the sputtering in your foot with more throttle.
I assumed that you have already changed all your valve springs since you had one break....
Old Dec 24, 2005 | 06:20 PM
Evo98z's Avatar
Yea i pulled the valve covers and i broke another spring on the exhaust valve on cyl.#2. Oh well i have some new springs to swap them out with.
Thanks guys for your help and have a MARRY CHRISTMAS
Old Dec 26, 2005 | 07:25 PM
joecar's Avatar
You need to find out why your valve springs are breaking.
