LS1 edit for 01 is available - Need some tuning advice
Old Apr 22, 2002 | 02:56 PM
TAhawk69's Avatar
Default LS1 edit for 01 is available - Need some tuning advice
My performance shop says they will have the 01 version this week. I need some help with deciding what to change. This is my list of mods:
2001 T/A A4
Yank ST3200
Air lid w/K&N &baker hose
SLP dual dual catback
Also getting an offroad y-pipe
and 180 thermostat before the tune.
I know I can have the fans turn on earlier
And the ses light from no O2 simms turned off
Get the proper Air/fuel mix
What about torque management
and converter lock up speed
Any info is apreciated
Thanks
Old Apr 22, 2002 | 03:26 PM
ChrisB's Avatar
Default Re: LS1 edit for 01 is available - Need some tuning advice
You are in general going to want to get the O2 related SES codes deleted - also any air pump and cat test codes.
You may want your shift points/torque converter lockup point adjusted to your liking also.
Spark and fuel can be adjusted, though you really will want it on a dyno with a wideband to do this properly.
Chris
Old Apr 22, 2002 | 04:10 PM
Ragtop 99's Avatar
look for a topic from a week or 2 ago with "MTI" in the title. There is a discussion of lock-up and shift points that will give you some ideas to start with.
