Best fuel - 89, 92, 93 octane?
What fuel is best to use?
Someone on this board said the most power and best fuel economy is obtained from using the lowest octane fuel that will not result in detonation (pinging).
My car has high compression heads (11.5 to 1), mild cam and an upgraded valve train. It will run on 89 without pinging but I always use 93.
Any thoughts?
Any thoughts?
Well the point of a higher octane fuel is so that you can run more timing, higher boost, or more N2O...now any engine can probably "run" on 89 octane or whatever but the point is that you want to be able to get the most out of the engine so in order to introduce more timing then you have to give it a fuel that won't combust off of the pressure of the engine...This is where tuning comes into play...
