what all should I change on ls1 edit..please read
I saw a post a while back that had a list of things to set...change convertor lock up to xx, change shift to xx(part throttle etc. I did search but could not find. I have thundercam, stg 2 heads, etc. shifts at 6200 right now, where should i shift? timing? naything you guys can tell me to help? especially the part throttle driveability stuff that i saw before but cant find...
thanks,
thanks,
Re: what all should I change on ls1 edit..please read
6200 is too low. You really need to find out where your setup is making peak power (dyno) but I'd guess around 6400. With this, I'd shift as close to 6500 as possible. Set your rev limiter to 6700 to give you some room.
Mark
Mark
