LS1 edit. Can you lock the fuel/timing maps?
-Dave
why?
conditions are not static. weather, gas quality, etc. is constantly changing - even if slightly. The O2's give you precise feedback and allow for correction for this.
The point isn't to maintain some arbitrary fuel or timing value, but to maintain a consistent level of operation of the vehicle.
If you really want to disable closed loop feedback you can simply raise the temp to enable closed loop operation - effectively keeping you in open loop mode constantly.
Chris
Lets say the computer has a stock baseline setup that it uses. During driving it works off that baseline to keep the car running at optimum. If you change that baseline in LS1 edit, does the computer leave it alone and just works from those new points to keep the car running optimum? What im trying to say is....If stock it gives 25 degrees advance at 3500rpm and the computer works from there to keep the car running at optimum. Then say I changed it to 30 degrees advance at 3500 rpm, does the computer work from the new setting or over time does it relearn/rework itself back to the 25 degrees it had stock. Basically what im saying is..if I change something to make the car run better or make more power, I dont want the computer taking itself back to stock settings and ruining all the work. I also dont want to be reloading the tuneup into the computer every other day because the computer changes it. So I didnt mean if I set it at 30 degrees advance I want it to stay at exactly that, I just dont want the computer taking it back to stock. I want it to work from the new tuneup. I hope this makes a little more sense. Thanks
The "learning" features of the computer are restricted to mainly s-trim and l-trim fuel functions (based on these values, derived from o2 readings, a correciton factor is applied to the base calculated values).
There is also an adaptive knock learn function where upon certain conditions a set amount of knock retard can be taken out without actually experiencing a knock event. This is the only thing that would have effect on your timing levels.
But these closed loop controls should work properly. If the amount of timing you are giving the computer is causing the knock sensor to go off then you need to find out why. It's possibly it could be false, but generally I have had good luck with knock sensors working properly. If would verify proper operation and then adjust your timing tables to prevent activation of the knock sensor.
Same with the o2's - assuming proper operation you may need to tweak certain tables (if you have changed the corresponding hardware from stock) to bring the l-trim values in line - once you have them set up properly the o2 action is desireable.
Chris
