O2 readings
Old May 4, 2002 | 02:56 AM
geniusjester's Avatar
Default O2 readings
i just finished doin an ATAP run, and when looking at my ltrims and O2 voltages, i noticed that the numbers arent the same. for example my ltrims read, 3.4% for B1 and 4.1% for B2. The difference was also in the voltages where it read .9xx and .91x respectively. I was wondering if this was okay or should the readings both be the same for both banks?
Old May 4, 2002 | 03:25 AM
ChrisB's Avatar
Default Re: O2 readings
It is fine - you will almost always have slight differences between banks.
Chris
Old May 5, 2002 | 05:43 PM
thanks chris. how far apart can they be before i start worryin that a sensor has gone bad?
