I need the tables for an uncalibrated 85mm PACE MAF and Tables for Lucas 42.5#
If anybody has the tables for these two particular items I would love to have them. I want a base that I can at least start the tuning on my car with. I need to have an idea where to start with LS1 edit.
Moderator
Here's the MAF numbers:
Frequency 1500 1625 1750 1875 2000 2125 2250 2375 2500 2625
Flow Gm/sec 1.59 1.88 2.20 2.58 2.99 3.45 3.95 4.50 5.10 5.76
2750 2875 3000 3125 3250 3375 3500 3625 3750 3875 4000
6.46 7.23 8.06 8.95 9.90 10.91 11.98 13.14 14.39 15.74 17.19
4125 4250 4375 4500 4625 4750 4875 5000 5125 5250 5375
18.74 20.39 22.14 23.99 25.95 27.99 30.14 32.38 34.71 37.16 39.73
5500 5625 5750 5875 6000 6125 6250 6375 6500 6625 6750
42.50 45.41 48.47 51.67 55.02 58.48 62.10 65.86 69.77 73.82 78.06
6875 7000 7125 7250 7375 7500 7625 7750 7875 8000 8125
82.48 87.07 91.82 96.74 101.82 107.08 112.48 118.07 123.83 129.76
135.87
8250 8375 8500 8625 8750 8875 9000 9125 9250 9375 9500
142.17 148.61 155.26 162.11 169.17 176.44 183.94 191.72 199.80 208.06
216.62
9625 9750 9875 10000 10125 10250 10375 10500 10625 10750 10875
225.44 234.52 243.89 253.45 263.21 273.23 283.55 294.15 305.06 316.32
327.93
11000 11125 11250 11375 11500 11625 11750 11875 12000
339.92 352.32 365.16 378.47 392.30 406.70 421.70 437.34 453.69
135.87
216.62
327.93
Thanks...that is exactly what I needed <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
John,
Yes I thought I sent you a reply to thank you. This post was made before I sent you the request. I really appreciate you helping me out.
Thanks
Thanks
I just saw the post, didn't check the dates and didn't realize if you got the info or not.
<img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Best of luck.
BTW, at 11250hz, you may be maxing out the LS6 MAF in PCM read airflow with that nice motor. When your ready to run/dyno it, let me know and autotap your MAF flow and MAF Frequency. We may have to get you an extended MAF version capable of going to 68lb flow read.
Best of luck.
I don't use autotap John. I use a Snap On diagnostic tool. I can log the information and compile a chart of some type with the info though that way we can analyze it.
Thanks
Thanks
