How to monitor fuel pressure?
Pathological Modifier
Your fuel pressure should remain constant at any RPM range. It will dip for a brief period of time as you change throttle position untill the fuel pressure regulator catches up. The LT1's changed fuel pressure using a vacuum signal, but the LS1's just run a contast pressure.
Ryan K. <img border="0" alt="[Fluffy]" title="" src="graemlins/fluffy.gif" />
that would be a fuel pressure gauge you are looking for <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
u can loan one from pep boyw or just ask what stock fuel pressure is and i will tell you it will be 58-60 psi <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
