water temp guage
Old Dec 28, 2005 | 04:06 PM
BIRDONNOS's Avatar
Default water temp guage
well my water temp guage is not working all the time, i used hp tuners to scan my car i went for a 15 min ride around the block and the scanner showed a temp that went from 160 to 192 and then back down, but on the other hand my inside guage in the dash worked for about 5 mins then the guage stopped working, its a 98 and has just started doing this. according to my scanner the ecm is getting a correct reading, but my guage inside is sometimes working and sometimes not. any help would be appreciated.
Old Dec 28, 2005 | 04:29 PM
98turbls1's Avatar
98's are notorius for this...Well it's obviously between your ecm and your gauge OR it may be your sensor...Luckily I haven't had this problem yet and I'm switching to All autometer gauges...I would check your connections to everything and then go from there
Old Dec 28, 2005 | 04:35 PM
BIRDONNOS's Avatar
i checked the connections and they look good, if the sensor is going bad would the ecm get a correct reading and somehow the guage in the dash cluster not get reading due to a faulty temp sensor. or does the guage in the dash get its reading from the ecm or the sensor itself?
