chip vs ls1-edit
Old May 9, 2002 | 03:17 PM
Zshark's Avatar
Default chip vs ls1-edit
chip is a lot cheaper, ls1 edit does more things, which to buy? If i bought a chip would ls1 edit work with it, or would it just get in the way? Would i need ls1 edit with just bolt-ons?
Old May 9, 2002 | 04:17 PM
ChrisB's Avatar
Default Re: chip vs ls1-edit
What "Chip" are you going to buy?
Chris
Old May 9, 2002 | 07:47 PM
Zshark's Avatar
Well, there was a few 'kits' selling for $15 on ebay. I assume they are chips. They describe it as fooling the engine that the air is cooler than it is, and thus raise timing and increase fuel pressure. What chip would you suggest?
Old May 9, 2002 | 08:00 PM
red ws6 99's Avatar
There are no chips for the Ls1, its not like the older setups where you can just replace a prom with a new one. Also fuel pressure is constant on cars from the factory and the computer can not control the fuel pressure.
The other thing you mentioned sound like the Inlet air temperature (IAT) trick, you basically put resistor inline with the IAT sensor and trick the computer into thinking it colder. Not really tuning, actually its bad idea.
Gary
Old May 9, 2002 | 08:18 PM
Zshark's Avatar
Ok, yes i had seen the IAT thing before too. I guess that the hypertech or ls1 edit is the only way then, is ls1 edit worth difference between it and the hypertech?
Old May 9, 2002 | 08:33 PM
Palm Beach Z's Avatar
If your just going to stick with basic performance bolt-ons, then I'ld say just get the HyperTech. My 98 liked the power programming with it. It was also very helpful in lowering the engine temp and when I changed gears.
If your going to do a cam and heads later, then I say go with LS1 Edit. You'll also need AutoTap or equivalent OBD II scanner with the LS1 Edit.
Old May 9, 2002 | 08:38 PM
Zshark's Avatar
Yeah, i freakin hate to spend the money, but i probably will mod the car futher, with all these freakin new fast cars comming out, i swear the new soccer mom stuff will be 600 hp before too long, Ls1's have got to keep their edge.
Old May 9, 2002 | 08:39 PM
Zshark's Avatar
But it is cool having a computer hooked up to your car, makes you feel like your nightrider or something
Old May 9, 2002 | 11:57 PM
MAXIMVS's Avatar
just wanted to point out that if he were to buy LS1 edit..there would be no need for a ATAP or Ls1 scanner.
LS1 edit has realtime reading capabilities <img border="0" alt="[Firebird]" title="" src="graemlins/formula.gif" />
Old May 10, 2002 | 12:18 AM
swtvictory's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by MAXIMVS:
<strong>just wanted to point out that if he were to buy LS1 edit..there would be no need for a ATAP or Ls1 scanner.
LS1 edit has realtime reading capabilities <img border="0" alt="[Firebird]" title="" src="graemlins/formula.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Really? So I can sell my a tap and HPP3 and MAFT and use the money for LS1 edit?
Old May 10, 2002 | 05:56 AM
Glenn98ZM6's Avatar
LS1 edit has realtime reading capabilities <img border="0" alt="[Firebird]" title="" src="graemlins/formula.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">thats news to me. i have edit and i dont think it does anything other than read the PCM's script and allow you to re-right and re-load it. there is no monitoring parameter in LS1 edit.
Old May 10, 2002 | 06:14 AM
bgreen's Avatar
LS1 Edit allows you to read your calibration, modify your calibration, and reprogram your PCM with a modified calibration.
No monitoring, you still need a scan tool of some sort to do this - ATAP, EFILive, EASE etc.
Monitor & watch/log parameters, based on the running conditions you observe, make changes in the cal in LS1 Edit, reprogram, begin the cycle again.
Brian Green
89 TTA
2001 Jeep TJ
