PAGING JULIO/CARTEK
Old May 12, 2002 | 11:17 AM
WS6 TransAm Girl's Avatar
Default PAGING JULIO/CARTEK
I'm wondering why I have a '99 program in my pcm now? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old May 12, 2002 | 01:19 PM
9T9BlueTA's Avatar
Default Re: PAGING JULIO/CARTEK
How do you know you have a 99 program? Did the file say it was a 99 PCM car? If it says that in the header of the edit file make sure the vin number is correct also.
One thing I can think of that is a long shot is check the build date on your car (in the door), maybe GM screwed up? especially if its a 2000 built early in 99.
<small>[ May 12, 2002, 01:19 PM: Message edited by: 9T9BlueTA ]</small>
Old May 12, 2002 | 04:20 PM
My program was an '00 before we brought it in to be tuned. Now when we looked into the actual program from my Cartek tuning, the VIN information is not where it should be for an '00 program. The VIN information is however, where a '99 program would be.
I am curious if it is in fact a '99 program now, and if so, then why? Is there was a certain reason that my programming was switched from '00 to a '99 for tuning purposes?
Old May 12, 2002 | 06:28 PM
T.J.'s Avatar
No reason. You just got screwed by paying for a custom tuning ls1 edit session, and ending up with somebody elses cut and pasted file, thats all. Though you should of known what you were getting when it took longer for the tuner to get there (2hrs with an appointment) than it did to actually mess with the car, dont want to say tune but anyways. I believe when you were "tuned" in the first time you were told "this is where you want to be", with 403/376. Well I like the 415/392 much better, it feels great. Hopefully you like where your at now, unless you agree with the previous tuner that 403 is "where you want to be."
Now you know to stick with a tuner who is looking out for your best interests. Sean <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old May 12, 2002 | 06:36 PM
The Alchemist's Avatar
UNDER PRESSURE MOD
And to think, I got bashed for saying that going to another shop to get tuned was a conflict of interest.
I CAN'T WAIT to see what gremlins we find in my programming.
Old May 12, 2002 | 07:31 PM
adam12's Avatar
Julio would not screw you. He is one of the most knowledgeable people I know, and I have been to a lot of the other so called “tuners”. There has to be an explanation for what was done. Does your car make more power? Do you have a dyno sheet? I have trusted Julio and Cartek for a long time. They have never screwed anyone over. The results at the track will speak for themselves.
Old May 12, 2002 | 07:35 PM
adam12's Avatar
ws6transamgirl,
I just emailed you Julio's email address.
Old May 12, 2002 | 08:35 PM
Adam- I am not knocking Julio's knowledge at all. I am just wondering what the reasoning is behind the '99 programming in my '00 car.
To answer your questions, I was having issues with the car (popping, rolling idle, backfiring) so we decided to go back into the car and retune. I left Cartek dynoing in 403/376 SAE, first pull of the day (yesterday) at JD's relatively matched those numbers. After a few hours on JD's dyno, I was tuned in at 415/392 SAE... I am pulling over my previous torque peak number for over 2800 rpm's. There is a substantial difference all throughout the powerband for both power and torque. The car is a completely different animal now
So it is what it is, regardless of the situation I am happy with these final results.
What I want to know though, the only thing that I can't figure out, is why I have a '99 program in my car.
Old May 13, 2002 | 12:33 AM
ChrisB's Avatar
You will probably have better luck with email!
I am curious though - what year is your car in actuality?
Chris
Old May 13, 2002 | 12:50 AM
My email bounced back so I figured I would post up here.
My car is a 2000
Old May 13, 2002 | 07:22 PM
Tekhombre's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by WS6 TransAm Girl:
<strong>I'm wondering why I have a '99 program in my pcm now? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Erin, LS1-Edit can't change the vin in the ECM, I edit the original file that is in the car. The first thing I do is to read the ECM with Autotap and determine if there are any codes, then I read the existing program that is in your car, edit it with LS1-edit then write the program back to the car.
If your ECM vin number doesn't mach your car's vin number then it was already changed when you came in for tuning or some one reflashed your ECM after I tuned it and that must be done through a Tech-2 or by trying to hack the ECM.
BTW, I never got any email or phone call fron you.
Julio.
Old May 14, 2002 | 12:28 AM
JPR's Avatar
JPR
Julio,
What Erin is trying to say is that Dennis brought it to both of our attention when he looked at the PCM addy info, not on edit, that her VIN number was not on line #4020 as per a 2000 vehicle, it was on data line #6020, which is a Vin data line for 1999. Now, we will confirm both VIN numbers tommorow because I have no idea how her Edit advertised 2000 VIN # can function properly when all the data is referencing to a 1999 data line #6020. We are looking at the raw Binary/Hex data address for every function in the computer program that nobody else can see, and can't be seen with Edit. All we know is that she went in with a 2000 VIN location and came out with a 1999 location? Any insight to that would be helpfull? There is no harm in what has happened because the old file was saved and removed from her PCM and started fresh, we just couldn't undersatnd how the data recognition "hand shake" was possible with this discrepency. I guess it was more of a question for us more than it was a problem.
Joe.
Old May 14, 2002 | 08:23 AM
Julio, my car had an '00 program before tuning.
And like I said in this thread, my email bounced back, I had a cartek.net email for you. I didn't call because your shop isn't open Sundays and I was anxious for an answer.
Old May 14, 2002 | 01:18 PM
Tekhombre's Avatar
LS1-EDIT can't and doesn't have the capability of changing VIN numbers.
Maybe it was done when you guys tried to swap files by desoldering chips on the board or something. What year is Tomcat's? 99 or 2000?
Julio.
Old May 14, 2002 | 01:43 PM
JPR's Avatar
JPR
I don't think so,
"Maybe it was done when you guys tried to swap files by desoldering chips on the board or something. What year is Tomcat's? 99 or 2000?"
I am an excellent chip welder, J/K I don't think thats possible, unless I tilted the chip to one side when it was removed and the data slid around inside the chip. Who knows, I don't really care, it's just that Erin had a problem with that news. Tom Cat is a 2000 according to the dash plate VIN.
Old May 14, 2002 | 02:59 PM
And being as though the build date is listed on the door as Feb '00, I think it's safe to assume he is an '00 LOL.
Old May 14, 2002 | 09:35 PM
UNDER PRESSURE MOD
ROTFLMAO....!!!!
I think I have heard it all...
We'll see what my pcm turns up tomorrow.
Old May 16, 2002 | 12:27 AM
Spazeack's Avatar
i would really be intrested in hearing an answer to this one myself.
Old May 20, 2002 | 08:45 PM
TravWS6's Avatar
Sounds like someone screwed up your computer and had to swap it with a 99... thats all i can think of..
By Brett Foote | 2026-06-04 05:00:17
