What pc speed is best for edit????
Old May 13, 2002 | 08:03 AM
99pewterZ's Avatar
Default What pc speed is best for edit????
I know that the min. speed is 133, but what are all you edit users running right now 133,155,233 or faster. I'm looking at buying one right now (155) and want some advice. Would this be to close to the min. speed, would you suggest something else?
Thanks in Advance
Old May 13, 2002 | 09:14 AM
adam12's Avatar
Default Re: What pc speed is best for edit????
It worked fine with a Pentium 150 machine with 80megs of ram. Once I loaded Autotap and Ease and excel, the computer ran slow, but the apps worked ok. I have since switched to a pentium II400 and things work faster. To answer your question, ls1-edit will work fine on a pentium 150.
Old May 13, 2002 | 11:42 AM
ChrisB's Avatar
A p150 will work fine for LS1 Edit. It will also work fine for autotap assuming you use the DOS version.
Really though I would try and spring for something a little faster - like
http://www.compgeeks.com/details.asp?invtid=IBM600E-2B
You will have the ability to do a good bit more - you would actually be able to run excel decently on the laptop, and if you needed it for other things (travel, etc.) it would be a viable option.
Chris
Old May 13, 2002 | 05:23 PM
99pewterZ's Avatar
Thanks again for the replies and please keep those ideas comming!
Old May 13, 2002 | 10:14 PM
RCowan's Avatar
Also you can try www.pricewatch.com
Click "Not Exactly New" at the top,
Then click the link for Notebooks under "systems"
