Need some help with autotap numbers
Old May 16, 2002 | 08:53 AM
KatfishRacing's Avatar
Default Need some help with autotap numbers
Here is an autotap of a recent run at the track. The car hits the rev limiter on the 1-2 and 2-3 shift. The shifts are programmed for 6200 and the RL is set at 6600.
It has a hotcam, are stage 2 heads, macs, ported maf and whisper lid.
Auto Tap Page
Im just curious if anyone sees some other tuning issues that need to be resolved before I send it back to get retuned.
Thanks,
Mike
Old May 16, 2002 | 01:02 PM
Ragtop 99's Avatar
Default Re: Need some help with autotap numbers
you are getting a bit of KR and your B1 02 was a bit low, but they may be due to heat or your ported MAF. O2 sensor readings aren't always the most accurate either.
Old May 16, 2002 | 06:25 PM
Yeah, I noticed that, but the timing advance seems low and the MAF flow numbers seem low as well.
Old May 16, 2002 | 07:56 PM
Ragtop 99's Avatar
A ported MAF causes the MAF flow numbers to be low because more air is passing through the MAF than the MAF was calibrated for. Either put your stock ends on or have the MAF & timing tables properly calibrated if you want accurate tuning.
Old May 16, 2002 | 10:12 PM
Thanks, that is what I was thinking too. I am swapping in the stock ends to see what effect it has.
Old May 16, 2002 | 11:13 PM
BLUEBYU's Avatar
I also noted your MAF is low. Obviously the engine is running lean at WOT. Yes your O2's seem in the "range", but ,as Ragtop99 was also pointing out, they are different car to car and sensor to sensor. I would richen it up a couple of clicks and work back. BTW, I have a stock H/C valvetrain with all of the bolt-ons and run at about 32-34 lbs/min between 5300 -5500 rpm at WOT. The one thing that did make a huge difference is when I closed my SS hood ram system and now rely on the SLP CAI (which I have additional air ducted from the nostrils to the inlet of CAI). When I finally gave in to just having an great looking "non-functional" hood, I feel what I think would be a 10-15 increase in HP. I can feel it in the seat of my pants. Turns out that rubber strip I was "saving" turned out to be a $400 goal mine. My increases in MAF went from 29-31 to those numbers, which is a 10 -15% increase! If you correlate increased flows at optimum mixture (no KR) to increased enrichment...mo power.... If you do this you also need to change your mixture even a little more richer. I would start at 5% richer and work back.
The MAFT works great for these setups...do a mod and tweak it in 5 min. BTW, my exhaust consists of Hooker shorties, custom 2.5" y fitted w/ RT cats, and LM.
I think when I add Mac's and B1 cam my rate should go up dramatically...dunno. I will post back with the correlation for those that care <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> ...Later.
