How To Check Tps For Correctness?
After installing my shaner T/B last week, my idle is much higher now. It goes up to 13-1400rpm, and very slowly comes back to around 850. Like in stop-n-go traffic,when I push the clutch in ,idle goes way up,then very slowly comes back down. Any info on how to check the tps with a meter, or links on this how to, possible a relearn?thanks
https://ls1tech.com/forums/pcm-diagnostics-tuning/284479-finally-how-tune-101-a.html this would be a good start
Thanks, but I don't have a tuning program. Isn't there a way u can turn the key on, and measure the voltage, certain volts at closed, and not to exceed ad wot?, thanks
Sure, you can do that. I had a Haynes manual for my LT1 that gave the proper voltage readings (5V max, I think for that sensor). You just turn the key on, put your test leads on the input wires to the TPS and flip the throttle blade to see the output range.
Originally Posted by BULLET99Z28
thank you, anybody with any mo info, I think i will go with this, what wire do u stick the tester in, besides ground to chassis?
