Whats your Fan LSEdit Settings?
Old May 22, 2002 | 08:54 AM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
Default Whats your Fan LSEdit Settings?
Tommy's car is running 220 degrees so I'm thinking I must have the wrong temp settings installed with LS1 edit. He has a 172 degree thermostat, what temp settings should I put for
Fan 1
Fan 2
Thanks
Jason
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old May 23, 2002 | 07:17 AM
Camaroholic's Avatar
Default Re: Whats your Fan LSEdit Settings?
With a low temperature thermostat I like to use 195 / 205. That way, the fans don't run all the time, but they do run when the car starts to get warm. I've been using this on my LS1 car (err, and my LT1 car, and other guys' cars that I've programmed), and I think it's a good compromise between running the fans all the time and keeping things cool.
I don't like Hypertech-esq fan settings of 182/187 (in the LT1's), that's just too low, too likely to run those motors too much.
Just my opinion. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
-Andrew
Old May 24, 2002 | 12:39 AM
Sparky's Avatar
I agree, you want to give your stat time to open and the radiator to do its job.
Mark
Old May 24, 2002 | 09:37 AM
Ragtop 99's Avatar
I have a 160 T-Stat and use 175/184. I have FTRA & a tranny cooler and like the fans to come on before things get to hot, especially my tranny fluid.
Old May 26, 2002 | 03:19 PM
Sparky's Avatar
Hey Ragtop,
With that stat and those fan settings, what does you car cruise and idle at temp wise?
Thanks!
