Got Ls1 Edit...what to start doing...
Old May 23, 2002 | 03:02 PM
SSBoy's Avatar
Default Got Ls1 Edit...what to start doing...
I have the cables, the software is still on my computer. I dont know how to save it into a folder and download it onto my laptop. If anyone knows how to help me do that i'd appreciate it alot!!!!
First things first:
1.) delete rear 02's
2.) rais idle
3.) adjust shiftpoints
4.) turn on fans earlier
5.) PO300 delete
ARe those good for some of the basics? Would u consider any others? Now i do have lock up problems with my ST-3500. anyone remember how to solve that? Someone said that i have to do ADDITIONAL things other than just shut off that PO30 code. Something bout 139degrees-->140degrees??????
Anyways thanks for your help. I just hope i get figure out how to download it by this weekend <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
Old May 23, 2002 | 03:39 PM
Ragtop 99's Avatar
Default Re: Got Ls1 Edit...what to start doing...
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"> Something bout 139degrees-->140degrees?????? </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">That is the misfire detection temp.
Converter lock-up speed is something else to screw with. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old May 23, 2002 | 07:20 PM
SSBoy's Avatar
Ragtop:
thanks for the 'heads up' reply <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> So with the Temperature, i type in 139-->140 correct?
Did anyone have any trouble downloading the software when it was emailed to them? Im having a difficult time.
thanks
Old May 23, 2002 | 07:37 PM
TA/30th 1002's Avatar
I had a hellofa time getting it to my laptop.
Ken helped me a bunch.
What problems are you haveing?
Ron
Old May 24, 2002 | 01:25 PM
TR's Avatar
TR
Jack,
Give me a call when you get the time. Maybe I can help you out setting it up.
Old May 24, 2002 | 02:05 PM
Ragtop 99's Avatar
Yes, its a start/stop temp limit.
you can also reduce/delete TM too.
When adjusting your shift points, be sure to try raising your low TPS part throttle points. Makes the converter feel tighter.
Old May 24, 2002 | 03:04 PM
SSBoy's Avatar
Thankseveryone for your help. Im having trouble Putting the software into a big file and downloading it too. Troy, i think i'll give you a call, this downloading stuff confuses me <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
thanks!
Old May 25, 2002 | 05:54 PM
LS1 PWRD's Avatar
All I did was take the 3 files Ken sent and transfered them to floppies and saved them to a DIR on the laptop, expanded the ZIP file and ran INSTALL. Of course you have to have a floppie on the laptop to do this.
