PCM Reset?
Old May 26, 2002 | 05:14 PM
Chuck's Avatar
Default PCM Reset?
It's been a long time since I've done this: which fuse do you pull when resetting the PCM?
Remoce it with key on, wait ten seconds, turn off key, replace fuse and then start car? Is it the ignition or battery fuse?
Thanks,
Chuck
Old May 26, 2002 | 05:58 PM
dfarmercse's Avatar
Default Re: PCM Reset?
It is both the PCM fuses.
Old May 28, 2002 | 08:04 PM
super chicken's Avatar
Its the ECM-B fuse. <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
Old May 28, 2002 | 08:59 PM
rwb's Avatar
rwb
Turn the key on but do not start.
Pull the PCM Bat and PCM IGN fuses in the engine compartment.
Wait a few minutes.
Turn Ign. off.
Replace fuses.
It will take the car a while to relearn fuel and timing curves. <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" /> <img border="0" alt="[Fluffy]" title="" src="graemlins/fluffy.gif" />
Old May 28, 2002 | 09:02 PM
70 LS1's Avatar
Conversion master
Why can't you just disconnect the battery and hook it back up?
