Do I need to change the injector 'offset' when installing SVO 30 lb using LS1-edit..
Old May 3, 2002 | 08:04 AM
2000Firehawk's Avatar
Default Do I need to change the injector 'offset' when installing SVO 30 lb using LS1-edit..
Anyone know what, or if, I need to change these injector 'offset' table when switching over to 30 lb SVO injectors ? <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Thanks,
Dave
Old May 4, 2002 | 07:41 PM
Ragtop 99's Avatar
Default Re: Do I need to change the injector 'offset' when installing SVO 30 lb using LS1-edit..
I didn't, but that doesn't mean that it is the right answer. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> This bumps it to the top.
Old May 15, 2002 | 03:12 PM
Scalpel's Avatar
TTT
Old May 23, 2002 | 01:14 PM
Sparky's Avatar
I'd like to know to!
TTT for ya!
Old May 23, 2002 | 04:46 PM
Scalpel's Avatar
Can we contact SVO for the offset?
Old May 23, 2002 | 06:11 PM
Batmobile/SS's Avatar
This is a comparison of offsets I found on the net
GM 24# Multec
0.00 1.60 3.20 4.80 5.20 5.60 6.00 6.40 6.80 7.00 7.20 7.60 8.00 8.40 8.80 9.00 9.20 9.60 10.00 10.40 10.80 11.00 11.20 11.60 12.00 12.40 12.80 13.00 13.20 13.60 14.00 14.40 14.80 16.40 18.00 19.60
8.36 8.36 8.36 8.36 8.36 8.36 6.00 4.29 3.18 7.00 2.59 2.20 1.90 1.67 1.47 8.90 1.28 1.11 1.05 0.92 0.82 11.00 0.72 0.59 0.52 0.46 0.39 13.00 0.36 0.33 0.29 0.23 0.20 0.07 0.07 0.07
Ford 24# SVO
0.00 1.60 3.20 4.80 5.20 5.50 6.00 6.40 6.80 7.00 7.20 7.60 8.00 8.40 8.80 9.00 9.00 9.60 10.00 10.40 10.80 11.00 11.20 11.60 12.00 12.40 12.80 13.00 13.20 13.60 14.00 14.40 14.80 16.00 18.00 19.60
7.00 7.00 7.00 7.00 7.00 7.00 5.00 4.25 3.75 3.00 2.66 2.33 2.00 1.83 1.67 1.50 1.43 1.37 1.31 1.17 1.04 0.91 0.87 0.84 0.81 0.73 0.66 0.59 0.56 0.53 0.50 0.50 0.50 0.50 0.50 0.50
Ford 30# SVO calc
7.00 7.00 7.00 7.00 7.00 7.00 5.37 5.01 4.81 3.04 2.70 2.37 2.04 1.87 1.71 1.54 1.47 1.40 1.34 1.21 1.09 0.96 0.93 0.91 0.89 0.82 0.77 0.72 0.69 0.66 0.63 0.63 0.63 0.63 0.63 0.63
Ford 36# SVO calc
7.00 7.00 7.00 7.00 7.00 7.00 5.75 5.76 5.86 3.08 2.74 2.41 2.08 1.91 1.75 1.58 1.50 1.43 1.37 1.25 1.13 1.01 0.99 0.97 0.96 0.92 0.88 0.84 0.82 0.79 0.77 0.77 0.77 0.77 0.77 0.77
Ford 42# SVO
7.00 7.00 7.00 7.00 7.00 7.00 6.12 6.52 6.92 3.12 2.78 2.45 2.12 1.95 1.79 1.62 1.54 1.47 1.40 1.29 1.18 1.07 1.05 1.04 1.03 1.01 0.99 0.97 0.94 0.92 0.90 0.90 0.90 0.90 0.90 0.90
Lucas 42# (Ellis)
0.23 0.23 8.36 8.36 8.36 8.36 6.00 4.29 3.18 2.39 2.03 1.74 1.44 1.02 0.85 0.72 0.52 0.46 0.26 0.16 0.16 0.13 0.13 0.13 0.10 0.07 0.07 0.07 0.07 0.03 0.03 0.03 0.03 0.03 0.03 0.03
Old May 23, 2002 | 09:28 PM
Scalpel's Avatar
Batmobile, did you type this in as well as multiplying the injector scaling table through by 138% (assuming you have a 99-'00 LS1 w/SVO 30's?)
<small>[ May 24, 2002, 03:08 PM: Message edited by: NastyC5 ]</small>
Old May 28, 2002 | 09:18 PM
I did the 138% on the flow and tried a straight 125% multiplier across the offset table. This got me close on LTFT but I still had other issues with O2's and KR. The offset scale I found as "I" understand it is the Volts/Offset value at the 0. It does not account for vacuum across like the table in LS1edit. This has to be calculated. I gave up on injector offset for now and went to the MAF table to get my LTFT close to zero. I am close using 105% across. I do need to tweak it some across the frequency. My O2's went up and I am better on KR but still some there above 5500 RPM. Any ideas on the WOT relationship of Fuel Cell 15 and 22? I used to be almost always in 22 now its 15 with some switching between the two over a long run. I can't stress enough to make samll changes and test
