P0751 code and LS1 Edit problem
Old May 28, 2002 | 02:19 PM
Ragtop 99's Avatar
Default Re: P0751 code and LS1 Edit problem
not sure, but here are a couple questions.
There are 2 similar codes, 751 and 756. Did he turn-off both? did he disable the test or just the reporting?
Good luck. FWIW, I had MTI programming and it worked fine.
Old May 29, 2002 | 12:44 AM
Red 99 TX SS's Avatar
Default P0751 code and LS1 Edit problem
Jayson at MTI has turned off the P0751 code on my car but somehow that code keeps popping up about once a week. He checked the program and it shows that the code is turned off. Why does it still set an SES light if the programming has turned it off? Has anyone else had this problem.
Old May 29, 2002 | 03:09 PM
Ragtop
Thanks for the response. I'll check with Jayson to see exactly what was done. I didn't realize that you have to deactivate reporting and running of the test separately.
