resetting codes
Old May 28, 2002 | 09:08 PM
70 LS1's Avatar
Conversion master
Default resetting codes
I am pretty sure my car is running in limp mode due to a bad sensor input. Running rough at idle and surging. Does it shift out of limp mode when the condition clears, or doew the PCM need to be reset?
Old May 29, 2002 | 02:41 PM
Ragtop 99's Avatar
Default Re: resetting codes
It should clear out the next time you turn the car off & on. Running rich could be caused by a bad O2 sensor.
