ABS adjustable via tune??
Old Jan 3, 2006 | 09:09 AM
300bhp/ton's Avatar
Default ABS adjustable via tune??
Haven't been able to find the answer to this.
Is there anyway of adjusting the point at which the ABS kicks in?
Basically this is my biggest gripe with my Z28 that the ABS seems to kick in far to early, the wheels are not anywhere near lock up. And as soon as the ABS kicks in you loose pedal feel and reduced braking ability.
However I would like to retain the ABS as it is a sensible thing to have. Is it something that can be adjusted with something like HP Tuners or similar?
Old Jan 3, 2006 | 09:26 AM
SideStep's Avatar
I am almost postive ABS is controlled in the Body Control Module (BCM), at least on C5s, and HPTuner only does adjustments in the PCM.....
Old Jan 3, 2006 | 10:01 AM
Bombguy99z28's Avatar
Yeah, its BCM.
Old Jan 3, 2006 | 10:28 AM
300bhp/ton's Avatar
Is there anyway of editing the BCM?
