LS1Edit connector
Old Jun 12, 2002 | 09:15 AM
Dipstick's Avatar
Default LS1Edit connector
Does the cable for LS1edit connect to the DLC plug under the dash? Same place the Tech II and the Hypertech devices connect to? Does the key have to be on for the PCM to be re-programmed?
Thanks,
Mike
Old Jun 12, 2002 | 01:00 PM
Dipstick's Avatar
Default Re: LS1Edit connector
Tank you berry much. I have a friend?? that doesn't believe there is a tool that will allow you to defeat the anti-theft code. Then again, he doesn't believe anything I tell him. Only after someone else tells him the same thing. He thinks that all the car thieves would go out and buy LS1edit for $3500, carry a laptop and go around stealing Vettes and F-bodies.
Old Jun 13, 2002 | 12:37 AM
Camaroholic's Avatar
Yes to all. Engine off.
HTH,
Andrew
