Problem with cold idle
Hello codewhitfield is your check engine light on? Sounds like an ect sensor problem. Do you have any way to check the data stream and look at the ect sensor output?
Chris Macellaro
It could be a multitude of things but this would be the first place I would start looking and since you do not have diagnostic software or any sort of scan tool to check the data stream. I would recommend you take the car to someone who has the equipment to fix it or at least diagnose the car.
Good luck my friend
Chris Macellaro
I can not say for sure that is your problem but yes it is a possibility. A lazy or non working O2 could cause fuel enrichment issues.
Chris Macellaro
