EASE Question
Old Jun 12, 2002 | 03:12 PM
Vettepartz's Avatar
Default EASE Question
One of the parameters that can be set up in the EASE diagnostics is "Delivered Torque". Does anyone know if this is what the PCM calculates is at the flywheel or what? Also, does the Load % have anything to do with this?
Old Jun 12, 2002 | 10:59 PM
Team ZR-1's Avatar
Default Re: EASE Question
Yes delivered torque is at flywheel.
GM has a Bug to what is reported to OBD-II.
Autotap refused fixing the problem in their code but Ease worked with me and if your seeing DelTq values like 1200 ft/lbs, then it needs a patch, if you do not have it you can contact me since I worked on a fix and have the patch.
Load ( engine )is a different PCM function is good to record when your tuning and want to see if at hard or high RPM loads the engine is getting to 100% load or not.
<small>[ June 12, 2002, 11:00 PM: Message edited by: Team ZR-1 ]</small>
Old Jun 13, 2002 | 03:04 PM
Vettepartz's Avatar
Thanks, JR. I think you can see where I am going with this (torque times rpm divided by 5252) I did get the patch from you when I ordered the EASE. Any idea how accurate the EASE torque value really is?
JW
