Will LS1edit work without ATAP
Old Jun 13, 2002 | 08:41 PM
Satan's Angel's Avatar
Default Will LS1edit work without ATAP
I am going looking this weekend for somestuff for my car. I need to start tuning it...can I just buy edit or do I need atap to complement it?
Old Jun 14, 2002 | 07:18 PM
DravenMyers's Avatar
Default Re: Will LS1edit work without ATAP
You're going to need both ATAP and LS1edit. You won't know what to change without ATAP, in most cases. Besides, Auto Tap is good to have around. To make changes in your PCM you'll need LS1edit.
Old Jun 16, 2002 | 11:22 AM
ToplessTexan's Avatar
To echo DMs comments a little, you won't know the effect of your changes without measuring them in some way. Sometimes that'll mean a scantool like AutoTap, sometimes a WB O2, sometimes a timeslip, etc. Depends on what you're measuring. A scantool is just one more tool in your tool box, but you definitely want one. Randomly making changes w/o some kind of feedback is not a good plan.
Old Jun 17, 2002 | 12:41 AM
The Emperor Of Darkness's Avatar
don't the dealership has something like this??!?!!Auto-Tap??
I am just curious.....
Old Jun 17, 2002 | 10:11 PM
CamaroCain's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by The Emperor Of Darkness:
<strong>don't the dealership has something like this??!?!!Auto-Tap??
I am just curious.....</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Your local dealer should have Tech II which is basicly the same as autotaping.
Old Jun 18, 2002 | 10:28 PM
66ImpalaLT1's Avatar
I bought LS1Edit and dont have a decent scan tool yet. Until I have one I will only be altering codes, rev limit, idle speed and other static parameters.
I've been trying to hold out for datamaster.
Eric
Old Jun 20, 2002 | 04:08 AM
MDL-01C5's Avatar
Datamaster?-- I'm not sure I've heard of that before...what is it?
Old Jun 20, 2002 | 02:10 PM
Jadeeglide1550's Avatar
If the car is new... and you go to the dealer... well.. they are not happy campers when they see the PCM has been modded.. .and those nasties may just load the orig. program and you will be back at base one. When you buy the Hyperlink Programmer and load it in... they tell you to make sure you go back to stock setting when going to the dealer... because.. if the dealer puts you back to stock settings... you are screwed with the programmer since it has the stock program in it and will not acces the PCM.... Dealers are trouble... avoid at all costs.....
Old Jun 20, 2002 | 02:28 PM
OOOOOOOOOOOOps... I meant Hypertech not Hyperlink... sorry... must be getting old to fast... .LOL...
Good luck with your problem....
Old Jun 20, 2002 | 08:17 PM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by CamaroCain:
<strong>[QUOTE]Your local dealer should have Tech II which is basicly the same as autotaping.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">A Tech II is substantially more powerful.
