took out my GMSMAF today to install fernco and found black soot inside w/fuel smell.
On only ONE of the three sensors inside the GMSMAF I found black stuff which rubbed right off, I was wondering what that could be.. It was almost like a carbon buildup of some sort. Also I believe I smelled a little gassy as well.
I know that,
I was wondering if it is normal to have that black **** on there like that...
Thanks though
Thanks though
Spray the wires clean with some B&G intake cleaner.The wires probably dirty from an over lubed air filter.
Ya I understand K&N air filter oil can clog the MAF wires? I do not have first hand experience with it. I understand that Holley filters are MAF-wire safe.
Double check to make sure you have a good seal on your airbox!
actually guys, I have a FRAM filter? I will check my lid to make sure there are no leaks...
Thanks.
Thanks.
