Newbie to A-tap, what to look for?????
Thanks
Collin
-RPM
-Timing
-Knock Retard
-Both front O2 sensors (B1/B2 S1's)
-Maf Flow
You want to run the min number of parameters so that you capture as much data as you can. Some guys will log TPS and gear but on a 1/4 blast you can tell what happens by looking at the RPM's.
Mark
TPS (%)
Engine Speed (rpms)
Timing Advance (degrees)
Knock Retard (degrees)
LTFT 1 and 2
Front O2's
Sometime's MAF frequency
That is a basic get to know ya run to see what is up. For more in depth tuning stuff you look at what you need.
Eric
