P0107 map sensor low voltage??????
Old Jun 30, 2002 | 02:29 AM
bLuE11secTA's Avatar
Default P0107 map sensor low voltage??????
P0107 map sensor low voltage?????? what could be cuasing this trouble code
Old Jun 30, 2002 | 03:24 AM
Ross's Avatar
Default Re: P0107 map sensor low voltage??????
is it plugged in?
I'd also check for damaged wire, pinched, melted, frayed.
ohm out the connector just to make sure, clean it out too.
Old Jun 30, 2002 | 09:55 AM
where is the sensor located exactly?
