How do I eleminate TM with Ls1 Edit??
in Eng ---> Ignition ---> TQ Management
Max TQ 800, Abuse Mode 7000 RPM Spd 0...
TQ Reduction set to 0 for whole table,
Since I dont have TCS I also set it 0, both Tables
For Shift Points, I have all 3 Coloums like this
37
65
116
33
61
112
6150
6150
6150
6150
Not sure about TC lockup
<strong>I have a trans-go shift kit in mine but no other alterations. Will +15 work with that? Thanks for the feedback guys. I really appreciate it, James.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">+15 should be perfect. I have a buddy with that setting on his stock tranny and he has had no issues at all.
They really should rename that table, the only thing it does is regulate what your timing is during the shift.
<small>[ June 29, 2002, 04:10 PM: Message edited by: Reboot ]</small>
<strong>the "spark retard limit" table is always working on my truck, it will pull timing from the main timing table based on IAT. it pulls timing all the time if it is hot enuff, not just when shifting.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Well the default value in the table for our F-body's is -10 degrees so if that were the case, on hot days we would all be driving around with our timing set at -10 degreees of retard.
I have done several A-Tap logs and my timing is normal even on hot days but the timong on shifts now drops to +20 instead of -10.
Maybe it's different for trucks?
the spark retard limit" table is probably the easiest way to adjust for TM and the other table only comes into effect when the IAT is above 90deg and above, thats how it seems to work on my truck anyways.
Heres my thoughts on the tranny wear issue....
sure an engine making full power thru a tranny is gonna wear on the tranny quicker but older cars had no tm and they held up just fine. Think its just a little added insurance by gm to cut down on warranty. Dure they feel every little bit helps and a large percentaqge of ls1 owners don't care about tm and probably never have even heard of it.
i don't want to complicate things, i still think the "spark retard timing limit" table is still the easiest way to adjust out TM but it looks to me there may be other effects than just TM
