Any MAFT Experts Out There???
I need some guidance about how to set it up. My inclination is to set it a little lean at idle and a lot more lean at WOT because a leaner mixture makes more horsepower. My engine is stock, but that's about all that is on the car (see sig). Can someone give me some guidance about baseline settings, what adjustments I should make for temperature and humudity variations, and whether this thing will work better, worse, or not at all in conjunction with Hypertech tuning. By the way, I normally run 35-40% 100 octane and 60-65% 93 octane in my tank. My rev limiter is set at 6400. The last time I dynoed it I got what appeared to be false KR above 5200 rpm's with the Hypertech tuning (non-rfg) installed. This went away when the tuning was taken out. I have not autotapped the car. Plugs are fresh as are the O2 sensors.
Thanks in advance for any help anyone can give me.
Generally I have seen +10% to +15% on the low setting with a -5% on the WOT.... but each car is different due to different mods.
