Wideband oxygen sensor location???
Old Jul 2, 2002 | 03:43 PM
Blackbird's Avatar
Default Re: Wideband oxygen sensor location???
actually they should be putting the bung pre-cat for an accurate reading.
Old Jul 2, 2002 | 03:50 PM
Ragtop 99's Avatar
Up the tailpipe / cutout unless you installed extra O2 bungs on your headers. I installed the extra bungs on my Y-pipe and the shop I used to dyno only had a tailpipe wand. <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
Old Jul 2, 2002 | 04:39 PM
red ws6 99's Avatar
Pre-cat otherwise its going to take along time for the signal to stabalize (plus less accurate)
Gary
Old Jul 3, 2002 | 12:37 AM
Jadeeglide1550's Avatar
Default Wideband oxygen sensor location???
I have ordered a wideband oxygen sensor and controller to test the A/F ratio on the car. Hopefully to tune it in with the MAFT and LS1edit.
I have a question though....
When the cars are brought in to the places that have a wideband sensor, and put on the Dyno for tuning, does anyone know where the wideband oxygen sensor is placed. Are they removing one or two of the oxygen sensors, either before or after the cats... or are they inserting the sensor into the tail pipe.
Thanks for the help....
Old Jul 3, 2002 | 12:41 AM
2000 Camaro SS's Avatar
They put them in the tail pipe. Unless you are a good customer and then they install a bung into the exaust behind the cats.
Old Jul 3, 2002 | 12:51 AM
Would removing one of the rear Oxygen sensors and using a simm allow you to put the wideband sensor into the rear oxygen sensor bung??? If it would, then I would get two simms and two wide band sensors so I could tune in each bank separately.
What are your thoughts on that?????
Old Jul 3, 2002 | 08:21 AM
wizkid's Avatar
Install Director
Just do like the cool people do (me included <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> ), remove your cats permanatly and bam, you have two rear O2 bungs not being used. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
ERic
Old Jul 3, 2002 | 09:48 AM
Cool28's Avatar
Tire Smoking Tranny Blowing Director
or just run cutouts right after the headers <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> .
Old Jul 5, 2002 | 03:40 PM
cablebandit's Avatar
The Mustang dyno i used "In tune motorsports" in Cleveland tennessee removed one of my primary o2 sensors...the wideband o2 had a plug attached to it that passed thru the correct signal to the pcm. Pretty cool...
