tuning ?
Old Jul 10, 2002 | 11:34 PM
justin sutton's Avatar
Default tuning ?
I have a 02ss with a lid slpmaf hpp 160stat macheaders offroad ypipe under wot it smokes bad i was told it was rich but it uses oil to just need input. Thanks
Old Jul 11, 2002 | 12:04 AM
ChrisB's Avatar
Default Re: tuning ?
What makes you think it's rich? How was this verified? What color is the smoke? Have you put it on a wideband? Do you have access to a scan tool?
Chris
Old Jul 11, 2002 | 12:08 AM
At wot it reads 5 bars into rich on a air fuel ratio meter at wot. The smoke is white though
Old Jul 11, 2002 | 12:25 AM
All these people & no help?
Old Jul 11, 2002 | 01:08 AM
T/A Medic's Avatar
well if you are reading rich on wideband do u have a way to lean it? Usually rich is black smoke... white could be oil. ATAP ur car if u can see what ur LTerms are... any recent mods that might cause a change or did it start all of the sudden?
Old Jul 11, 2002 | 01:18 AM
ChrisB's Avatar
White normally indicates an oil consumption issue - a whitish-blue. If it's puffy cloud white that is more like anti-freeze. Fuel will be grey-black.
An a/f guage that hooks to your stock o2's is not a reliable indicator of how rich/lean you are at WOT though.
Chris
Old Jul 11, 2002 | 01:19 AM
This **** started as soon as i put the headers & ypipe on it blows black as soon as i get in it then automatically turns white.
Old Jul 11, 2002 | 01:33 AM
Well i will put it this way it has 16000 miles. I went to the track last weekend ran it 5 times hard,drove it all week & the damn thing was a quart & ahalf low today.I know ls1s use a little oil but damn.
Old Jul 11, 2002 | 03:01 AM
T/A Medic's Avatar
that is way too much consumption for a few days... if u have no cats u are going to be smokey some, better take it to dealer if ur burnin that much oil
Old Jul 11, 2002 | 03:31 PM
The thing i cant figure out is if it is oil passing thru the heads it would smoke all the time if it was a ring same there but it only does it while running the **** out of it.
Old Jul 11, 2002 | 04:12 PM
ChrisB's Avatar
I don't think it's tuning related - considering the oil usage. I would suggest posting your question in the engine section and see what the consensus is.
Chris
