HELP! PO327 & PO332 Knock sensor .
Old Jul 28, 2002 | 04:22 AM
  #41
Predator's Avatar
Default Re: HELP! PO327 & PO332 Knock sensor .
I have a thought: what are the chances that a battery that's on its last legs could be causing these codes? My battery is about shot, and it's the only thing I can find wrong with my car.
Old Jul 30, 2002 | 04:15 PM
  #42
MIGHTYMOUSE's Avatar
i have not tried it yet, but its looking like there are just some tables in the comptuter that are screwed up somehow that you can't touch with edit. therefore the whole deal must be dealer reflashed.. so thats what im going to try.
Old Jun 29, 2003 | 10:37 PM
  #43
Ed Blown Vert's Avatar
SIKLS1, I can't thank you enough mate! You helped me BIG time. I recently swapped out both knock sensors, and the harness, and after awhile I started getting P0327 and P0332. It never occurred to me that changes I had made in LS1 Edit was causing those codes. After reading your message, I remembered that I didn't start getting the codes until I changed my rev limiter settings (I upped the "rev by gear" to 6400 and changed the intial settings on the folder, only). I set everything back to stock and now the ks codes are gone. Again, thanks so much!
Best Regards!
Well I did the same thing change just the 'rev by gear'. And I also get the p0327 even though I changed both KS and harness. Guess I should change it back to stock.
Old Jun 30, 2003 | 12:43 PM
  #44
Zrevrun's Avatar
I'm getting the same codes myself, and it started after I had my PCM programmed after I put in my cam. I guess that I will also get it flashed back to stock and maybe try the predator to program it with.
Old Jun 30, 2003 | 04:50 PM
  #45
I would sure like to know what not to change.
Old Jul 1, 2003 | 07:31 AM
  #46
KOOL C5's Avatar
I would also like to solve this problem. It started after my 422 was repaired and a newer version of LS1 edit was used.
I'm going to go back and program on an older version of edit and see what happens.
I use Nitrous and would really like to use the KR fuction.
I have it turned off(327 332).
Old Feb 24, 2005 | 12:31 AM
  #47
MelloYellow's Avatar
ttt
Anyone ever confirm this bug or find a solution?
Getting P0327 intermittently right now...
