Air Pump Coolant Disable Temp in LS1 Edit
Old Jul 13, 2002 | 04:51 PM
wizkid's Avatar
Install Director
Default Air Pump Coolant Disable Temp in LS1 Edit
Picture of the Screen I am talking about
Anyone know what that number means? Is that the temp it kicks on at? So I should raise it to 300 if I don't want it testing to begin with? Be nice to get rid of that "flicker" when the car is testing the O2's.
Another thread about it here but it never got confirmed.
Eric
<small>[ July 13, 2002, 04:52 PM: Message edited by: wizkid ]</small>
Old Jul 14, 2002 | 07:41 PM
MIGHTYMOUSE's Avatar
Default Re: Air Pump Coolant Disable Temp in LS1 Edit
mine is set to the max value, which is 150.. i have no pump on the car and with the error codes removed also, all is well.
this disables the air pump test at any temp under -10*C now mine is disabled any temp under 150*C
Old Jul 14, 2002 | 08:02 PM
wizkid's Avatar
Install Director
How do you know it is degree's C and not F? Sounds like you got it correct though if you don't have any problems.
Thanks!
Eric
Old Jul 15, 2002 | 12:16 AM
because everything else ive seen in edit is in *C
