Atap reading problems...help.
Old Jul 14, 2002 | 08:28 PM
BLUEBYU's Avatar
Default Atap reading problems...help.
I am trying to log "recent gear shift" and "engine oil pressure". The log always indicates the gear is in first and the pressure stays at a constant number of 14. Why am I not seeing the correct data. It appears to be at the base line reading and just sets there not adjusting. Could it be I need to slow the rate of retrieval for those parameters? I will probably try that tomorrow...any input? TIA
Old Jul 15, 2002 | 07:30 AM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
Default Re: Atap reading problems...help.
"current gear" I believe is what you want under Transmission.
The oil pressure is not a supported parameter on our cars. Mine always reads like "-14".
