Another ATap ?
Old Jul 14, 2002 | 08:40 PM
BLUEBYU's Avatar
Default Another ATap ?
How can you use the "pulse width" to show "% Duty" on the injectors? I believe the units are
"m/s".
Thanks.
Old Jul 14, 2002 | 08:58 PM
ChrisB's Avatar
Default Re: Another ATap ?
I don't have autotap handy so can't tell you if it is a display option in there.
But for our purposes
injector duty cycle(%) = injector pulsewdith(msec)* rpm / 1,200
This gives you duty cycle in units of percentile. The 1,200 is just a constant that reflects the 4 stroke /v8 setup and percentile conversion.
Chris
Old Jul 14, 2002 | 11:40 PM
BLUEBYU's Avatar
This forum rocks!!!! <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" /> Thanks for the insight, Chris. What are the guidelines for injector duties? When should you upgrade?
Old Jul 15, 2002 | 12:04 AM
ChrisB's Avatar
If you are going to be running flat out for long periods of time at high rpm (roadracing, silverstate, cannonbal run type things, etc.) then I would go with the classic 80% rule (no more than 80% duty cycle). For drag racing, short bursts (less than 1 min, etc.) 90-93 percent is about the max I would go.
Chris
