Putting together an LS1 edit FAQ - need input on topics ->
Old Jul 18, 2002 | 03:37 PM
SIKLS1's Avatar
Oz Director
Default Re: Putting together an LS1 edit FAQ - need input on topics ->
Originally posted by Chris:-
I understood that it was very difficult to delete all the MAF related information in the pcm? Are you actually able to do this with ls1 edit?
Yes if you want i can send you the list of Hardware Diagnostic that you turn off, and bingo you in speed density mode.
The GTS here in OZ run NO MAF at all, so it relies on running the car in this mode.
Did you get around and have a look at my site???
Another question the below equation
Air density can be determined using: (MAP – Vapor pressure(H2O)) --------------------------- 0.287 * IAT(in Kelvin)
Is there and easy way to work out Air Density, like how do you workout Vapour pressure( H20)??
One more question, you need to setup how to make Pivot Table, i'm no expert when it come to Excel, so if you can do something similiar as my web site, explain the step by step on how to do the correctmaf.xls
Just capture the screen shot and show the correct way to go about it.
Have a look at my site you see.
Old Jul 19, 2002 | 06:47 AM
DBerry's Avatar
Chris, I didn't read all of the posts, someone may have already mentioned this. Would it be possible on the Modified files to give a little better explination of the car that it was for.
I.E. You've got a 99 Camaro SS that says spark/fuel tuning. Was it tuned because of H\C or NOS etc.? On those files more specifics would be nice.
Old Jul 25, 2002 | 04:54 AM
AzzHauler's Avatar
From: Richmond, VA Where fast cars, well......are hard to come by.
I'll send you the outline later today or this evening.
Old Jul 25, 2002 | 10:18 AM
Tin Indian's Avatar
Setting transmission line pressure to vary directly with the throttle position sensor
I have seen this posted a few times before, but dont know if this can be acomplished with LS1Edit.
If so, maybe a section in Faq that details this:
1. Effects
2. How-To
Old Jul 25, 2002 | 10:24 AM
Tin Indian's Avatar
Setting Shift Points on A4 cars
This may sound very basic, but, I understand the 98 LS1 cars [may] have its shift points set by vehicle speed and NOT rpm like later model years.
If so, it would be valuable if the procedure for the 98 A4 cars be outlined.
Ron,
Old Jul 25, 2002 | 11:07 AM
rbartick's Avatar
How about a how to section that describes how to change your closed loop LTFT values. For example, someone installed an airbox and the LTFT values went up. How would you modify the MAF tables to bring the values back down.
Basically, how can you do with LS1edit what a MAFT does.
<img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Jul 25, 2002 | 01:13 PM
Vettepartz's Avatar
Chris,
I have a pretty good success story involving the removal of a MAF screen and porting the MAF ends. It tells the different things I had to do to get the desired results. However, to really do it justice, a picture I have needs to be included. Is this the type of thing you are looking for in your FAQ section?
Old Jul 26, 2002 | 12:54 AM
Justin2000Z28's Avatar
If somebody could find it in their heart to send chris a flash file from a 2000 Camaro or Firebird with a 8+ psi procharger kit, Headers, & no cats I'd be very happy. Anything similar would do.
I've been complaining in the Forced Induction section for almost a week on how my car put out numbers typical of a 5psi kit on completely stock car. I'm down at least 40 HP due to bad tuning from superchips. I've never tuned a car before so it would be nice to have something to start with. A guy I've been talking with has a similar setup but turns a few hundered more rpms than me and his is putting out over 480 RWHP since he got his tuning optimized after it was screwed up from superchips. Mine put out 420 RWHP on a muggy 80+ degree day. Nooooot good!
Old Jul 26, 2002 | 03:24 AM
AzzHauler's Avatar
Check your pm's Chris. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Jul 27, 2002 | 10:18 PM
PewterZ28's Avatar
Question: How do I raise my shift points, matching both rpms AND mph? With 3:23 gears?
Answer: Still not sure because I have seen many different numbers thrown around already.
My point is, if this FAQ site is going to be done, please make sure the answers are 100% accurate. I am sure you will do a great job. This is a great idea. I would also like to see people share their programs, or at least pieces of it.
Old Jul 28, 2002 | 12:51 AM
ChrisB's Avatar
AzzHauler - thanks for the outline!
The glossary section isnow up and semi-complete.
As to 100% accuracy - I try my best to put in the correct answers/facts, and have put in ???? for situations I am not sure, but of course, that is no guarauntee of 100% accuracy. If anyone has an comments/corrections, feel free to let me know also.
I will be getting started on the FAQ now
Chris
Old Jul 28, 2002 | 03:48 AM
  #32
Predator's Avatar
Chris, thanks for addressing my question (on your site) about transferring MAFT settings with LS1 Edit.
I don't know if this has been covered, but how do we "desensitize" the knock sensors?
Thanks again!
Old Jul 28, 2002 | 09:36 AM
  #33
Predator's Avatar
Chris, I just want to let you know that with your help I was able to remove my MAFT this morning. Not only that, but I was able to tweak my base setting at x112% rather than being limited to 5% increments with a MAFT (+5, +10, +15, and +20%).
Appreciate your effort!
Old Jul 30, 2002 | 07:25 PM
  #34
NoGo's Avatar
I would just like to thank you for your effort. I just recieved my LS1 Edit yesterday, and your page has become the bible.
Thanks again, and keep up the good work.
Old Aug 17, 2004 | 12:48 PM
  #35
marc_w's Avatar
Here's an oldie!!
It looks like a few things on the FAQ are outdated. (VE table jumped out at me).
Is the FAQ still maintained?
Does anyone have more info to add to it? I can think of a few things.
After reading a post from Humpin on the IFR table, I realize that a FAQ would have helped me out LONG ago.
I have some space on a server - I'll gladly put up a page up. I'm by no means even an intermediate tuner, so I don't want to put any "hardcore" info up without some verification and proof-reading.
If there is any serious interest in another Tuning FAQ site, just let me know one way or another.
Old Aug 17, 2004 | 01:33 PM
  #36
ls1290's Avatar
Dumb Ass Vette Moderator
I would LOVE to see a document/FAQ/HowTo for each section of LS1Edit. Something like how the LS1Edit User's Manual is laid out but have a good explanation of the section. Using the widgets label for an explanation is pretty lame. The LS1Edit mailing list has talked about this a couple of times, but nothing has really developed. I myself would be more than will to pay a good price( about $150ish or more ) for a document that has a good explanation of what each section does.
