Keep throwing P0103 codes
Old Jul 16, 2002 | 07:43 AM
StevieZ's Avatar
Default Keep throwing P0103 codes
Using my stock MAF with the screen, or with TR ends or with a brand new SLP 85 mm , it is always the same. It will usually throw the code when shifting under full acceleration. Any ideas?
<small>[ July 16, 2002, 07:44 AM: Message edited by: StevieZ ]</small>
Old Jul 16, 2002 | 10:35 AM
AzzHauler's Avatar
From: Richmond, VA Where fast cars, well......are hard to come by.
Default Re: Keep throwing P0103 codes
Got a maft? P0103 is for high maf frequency. I got it all the time before I got edit. My maft had to be set +15% base and +2% wot for NA, that would sometimes trip it, but setting +15% and +10% for nitrous got it every time. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> There is a built in threshold for maf freq, mine was 11250Hz I believe. If you have a maft, try turning it back a notch or 2 and see if you can prevent it w/o any problems. Otherwise don't worry about it, it'll cut off the light after a while as long as you don't trigger it anymore. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Jul 16, 2002 | 01:47 PM
StevieZ's Avatar
That must be it. I have the maft set at +15% base and 0% WOT. I will try to set it at +10% and autotap it.
