O2 units of measurement for ATAP v2.02?
I just ran my AutoTap v2.02 for the first time and I can't seem to find the old O2 PIDs (where it'd show the oxygen sensor readings between 0 and 1000 milivolts). The only O2 readings I get are numbers like 2.7, 3.7, 3.9, etc. How do these numbers relate to A/F ratio? Thanks.
You did not make a mistake, I also tested with V2.02 and as the norm it is screwed up and giving incorrect values as another of their scanners scale with invalid results.
I also got values of over 2000 ft/lbs of torque and that was at idle.
Location: Richmond, VA Where fast cars, well......are hard to come by.
That's how mine logs the O2's also. Everything else records fine, but those don't. In real time it shows the millivolts correctly, even while recording, but playback is whacky.
