What are these codes?
Old Jul 23, 2002 | 08:51 PM
justin sutton's Avatar
Default What are these codes?
I was wondering if anyone knew these codes or where can i find out on the net? The codes are 103,133,&300 <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Jul 23, 2002 | 09:14 PM
R U A LS1's Avatar
Default Re: What are these codes?
hmmm usually they're longer than that...have you tried the SES code translator at the top of this page?
NastyWS6's Avatar
300 is a multiple misfire code, not positive about the other too.
Old Jul 23, 2002 | 09:38 PM
Sorry didnt know there was a code translator there.The P0300 is engine misfire,P0133 is H02s insufficient bank1 sensor1,& P0101 is maf sensor performance.What could cause this & what could they mean? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Jul 25, 2002 | 07:09 PM
NastyWS6's Avatar
The misfire code may be fouled plugs or bad plug wires. pull a couple plugs and inspect them to see if your car is running too rich or too lean.
Old Jul 25, 2002 | 09:58 PM
wolfman jack's Avatar
as far sa the p0300 goes for gm cars it is a general misfire code. you need to find out what cylinder(s) set the code look in the misfire graph or in misfire data under history of misfires but remember that misfires are detected and counted by the ckp (crank shaft position sensor) and that a misfire can show up on the cylinder before and after the problem cylenderin the fireing order. ps. the fireing order is not the same as the old small block
