discrepancy btwn injector correction factor and excel data
Old Jul 24, 2002 | 06:24 PM
MIGHTYMOUSE's Avatar
Default discrepancy btwn injector correction factor and excel data
which way should i use to calculate the flow rate table?
using the correction factor method here:
godspeed injector scaling page
i get these first 3 data points for42# injectors
(for 98 injectors flow rate using 98 1.696 correction factor) -> 6.13952 6.17344 6.20736
(for 99 injectors flow rate using 99 1.837 correction factor) -> 6.11720 6.15533 6.19322
why are the above not identical? or the same as the following?
using the injector scaling excel spreadsheet here:
Godspeed's Injector scaling excel spreadsheet
(running the numbers for 42# injectors at 43.5 psi they are) -> 6.110675 6.148758 6.186607
which one do i use? please help and let me know if i need to clarify anything, again these are the first 3 values for the injector flow rate vs. map values of 0,,5,10 kpa respectively
Old Jul 25, 2002 | 11:30 AM
Default Re: discrepancy btwn injector correction factor and excel data
yes help please
Old Jul 26, 2002 | 02:38 PM
same here, i really need to know this as well <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Jul 26, 2002 | 03:01 PM
cablebandit's Avatar
use the 98 scale....remember that 98 had bigger injectors than 99 so the pcm is different. You will probably end up changing it anyway after watching ltrims. I used a stock maf so my ltrims were adjusted with the injector constant
Old Jul 26, 2002 | 03:41 PM
i thought the same thing, but if you look at the math, the numbers fall out, they are used just to gain a ratio of flow vs. #/hr.
or still why not use the calculation from the spreadsheet at the bottom vs the 98 setting?
Old Jul 30, 2002 | 04:18 PM
cable, did you touch the offset table to do the 42# injectors? i have no info on this.
im gonna try the 98 table, but the excel calculated value seems to have some more meat behind the numbers.
Old Jul 30, 2002 | 04:48 PM
ChrisB's Avatar
this is what I use to calculate injector flow rates
http://www.speeddemonmotorsports.com...ectorscale.xls
Chris
<small>[ July 30, 2002, 04:49 PM: Message edited by: ChrisB ]</small>
Old Jul 30, 2002 | 05:24 PM
yes that is the spreadsheet link i have shown above. notice the outputs are different than that which was pulled from the table for the 98 cars.
now i still dont know which to use. does it matter?
Old Jul 31, 2002 | 06:51 AM
i didnt use any. I am using a vacuum/boost referenced regulator with no intank regulator. I set my injector constant to 5.51 all the way across the board. FP is set at 60 with the hose off. my ltrims range from 0 to -3.9 This is with the svo 42# injectors. I am really happy with them.
Old Jul 31, 2002 | 11:22 AM
ChrisB's Avatar
Mightymouse: The spreadsheet link above is the one I and use. AFAIK it is correct. The injector flow values should not depend on model year; they are absolute values. I would (do) use the spreadsheet.
Oh, and it's not Godspeed's, it's mine <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Chris
Old Aug 1, 2002 | 12:35 AM
ok, well i guess he used it and posted it in a reply of his on the same subject once, without giving due props.
props to you, you are a smart dude. i will use the spreadsheet values, now i have everything i need assuming the injector offset is the same for all years of ls1's., or at least that the offsets on the ford 42 were gained from starting with a 98 injector.
