changing knock retard gain??
does anybody understand what I mean...
plugs are good, compression is good all cylinders, 11.0afr wot so the combustion chamber could be getting a little black...
I actually increase the gain so it pulls more timing if it sees knock. Turning it off in that range is a really bad idea.
To find out if it's false knock fill up with some 100 octane and see if you still get knock. Just because you can't hear it doesn't mean it's not detonating the **** out of the motor.
Then, assuming it's real and that you only want to recover faster after you are out of the knock range, then my understanding is that the recovery rate is what you want to mess with.
And as long as you are in there tuning, perhaps you should fatten the mixture a bit in that target RPM range, or just drop an additional degree of advance.
Or the other early c5 KS problem,where you have to remove the intake,and build a moat around the rear sensor because the water gets in there and ruins the sensor.
Damn Assasin,didn't you live in Maui not to long ago?Looking for z rims...?
what was the fix for the idler pulley, get a new one?, I know when the engine is running I can hear that thing just a little...
Man,why did you move?Work?At least you kept the car.Now your getting into tunning sweet....you know you'll need it if you ever come back this way.
And no, removing timing cannot contribute to knock, but you might lose power. Have you pulled timing in the program since you boosted it? Boosted motors require less timing.
Bulletin: Audible Spark Knock (Detonation),
Subject: Audible Spark Knock (Detonation)(Replace Rear Bank Knock Sensor and RTV Area Around Sensor)
Source: Chevrolet Dealer Technical Service Bulletin
Number: 02-06-04-023
Models: 1998-2002 Chevrolet Camaro, Corvette, 1998-2002 Pontiac Firebird
with 5.7L Engine (VIN G -- RPO LS1)
1999-2002 Chevrolet and GMC C/K Pickup and Utility Models (Avalanche, Silverado, Sierra, Tahoe, Suburban, Yukon, Yukon XL, Yukon Denali, Yukon Denali XL) with 4.8L, 5.3L or 6.0L Engine (VINs V, T, Z, N, U -- RPOs LR4, LM7, L59, LQ9, LQ4)
Condition:
Some customers may comment on a mild to severe engine ping (commonly referred to as spark knock), usually worse during acceleration and/or an illuminated MIL. Upon investigation, the technician may find DTC P0332 set.
Cause:
This condition may be the result of corrosion of the rear bank knock sensor due to water intrusion into the sensor cavity. This condition is more apparent on vehicles in which customers frequently wash the engine compartment.
Correction:
Replace the rear bank knock sensor and build a dam (wall) around the sensor using RTV to divert water away from the sensor. Use the procedure and part number listed below.
the 100octaine didnt help, I droped the timing even more, af is 11.0, still periodic knock, I'll check into the idler and the knock censors....
