Injector offset table for Lucas 42's
Old Jul 30, 2002 | 02:33 PM
Blackbird's Avatar
Default Injector offset table for Lucas 42's
Chris has given me some links and such to injector offset but unfortunately at this point it is all greek to me.
I was wondering if anybody already has the table built I could take a look at to give me a good head start.
Thanks in advance.
Old Jul 30, 2002 | 04:20 PM
MIGHTYMOUSE's Avatar
Default Re: Injector offset table for Lucas 42's
i would like to know as well, p.s. if you have any info on the 42# constant to use read this post here, thanks. Ls1tech link
Old Jul 30, 2002 | 04:47 PM
ChrisB's Avatar
I posted this table and it includes a conversion for the Ford 42#/hr injectors using the factory ford offset values, converting to LS1 values.
http://ls1edit.slowcar.net/injectoroffset.xls
it can be easily switched to calculate the offset for the Lucas 42's - you just need to change the offset values on the second page, and the first should update properly.
http://carprogrammer.com/Z28/PCM/Injector/injectors.htm
has a couple of offet value lists, in LT1 style.
Chris
Old Jul 31, 2002 | 10:29 AM
ah, well i have ford 42's so thats dead on what i need! thanks dude.
Old Jul 31, 2002 | 11:41 AM
Blackbird's Avatar
I still don't understand it.
How do I know what to change the offset values to?
And did you mean change page 1 so it updates page 2? Page 2 has the complete table like it looks like in edit.
I am soooo <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Jul 31, 2002 | 11:23 PM
Blackbird's Avatar
anybody?
someone's gotta have Lucas 42's all dialed in that would be willing to share.
PLEASE <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Aug 1, 2002 | 09:11 AM
SJH's Avatar
SJH
I use stock offset values for a 98.
I run a vacuum referenced feul pressure regulator.
45psi at idle and 55psi at wot.
I use 6.1 gms/sec flatlined across the table.
Works very good.
Steve
