FTRA + A/F ratio
1. Does anyone know through any testing roughly how many points FTRA effects your A/F ratio?
2. I noticed at my last DYNO session that the cars making the most power started lean and richened up at the top end? For instance one guy imparticular had about a 13.5:1 A/F ratio prior to 4000 RPM's and 12.7:1 from 4000 RPM's to redline. He made good power throughtout the RPM range.
3. Should LTtrims always be zero at WOT?
4. Is it bad to have your MAFT WOT switch on the rich side? I've been told that shouldn't be necessary?
Any advice will be helpful!!!!
Note: I do have ATAP and know about O2's being between .88 and .91 at WOT and LTtrims at part throttle being as close to 0 as possible but since I had the wideband seesion am just thinking a little differently.
