Question about toggling Engine Diagnostic tests...
Old Aug 2, 2002 | 07:56 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Default Question about toggling Engine Diagnostic tests...
Are there supposed to be any tests turned “off” in stock form? I’m trying to get all my tests back to an emissions compliant state from my base MTI LS1 Edit tune, and I’m not sure what all exactly they shut off. It seems that I have a lot of DTC tests toggled to off and I’m not sure if that’s how it was stock or if MTI turned them off.
So again, are any tests in an “off” state on a stock PCM?
And what happens if I turn a test "on" that is supposed to be off, but leave the MIL light as type X (off)? Will it cause issues?
<small>[ August 02, 2002, 08:00 AM: Message edited by: RPM WS6 ]</small>
Old Aug 2, 2002 | 09:01 AM
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
Default Re: Question about toggling Engine Diagnostic tests...
The DTC list you see in LS1 Edit covers ALL applications of the engine for the year that you have (F-body, Y-body, and truck). So tests that don't apply to your vehicle are indeed turned off. The best way to get it all back to stock is to either reflash a stock file to your PCM, or get the factory service maunal for your year of car. It lists all of the diagnostic tests that are active, and tells when or if the MIL comes on or not. I would think that turning all of the tests on, when some don't apply, could cause issues. The PCM could set codes that don't even apply to your vehicle.
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
Old Aug 2, 2002 | 09:04 AM
RPM WS6's Avatar
Very good points.
Does Helms list what tests are active? I’ve never looked in there for that info before.
Old Aug 2, 2002 | 09:32 AM
Speartech's Avatar
Yes, all of the codes listed in a particular FSM are active for the vehicle covered unless it has an "X" status. You'll see those on the page where they compare a domestic federal emissions car with a leaded fuel export. The export car will have most of the emissions DTC's set to "X". It's a pretty neat comparison, and all on one page.
__________________
www.speartech.com
Old Aug 2, 2002 | 09:44 AM
RPM WS6's Avatar
Thanks, I will look for that page. What is FSM?
Also, I copied to disk some of the stock PCM files for my model year from ChrisB’s site. I will look at them and see what the codes are set to just for further reference.
Old Aug 2, 2002 | 10:00 AM
Speartech's Avatar
FSM = Factory Service Manual
__________________
www.speartech.com
Old Aug 2, 2002 | 11:29 AM
NoGo's Avatar
What year, and what type of car do you have. I just got edit as well, and took a read of the my stock PCM. I would be happy to email the read to you so you could go down the DTC list.
I have a 2000 M6 WS6
Old Aug 2, 2002 | 11:45 AM
RPM WS6's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by NoGo:
<strong>What year, and what type of car do you have. I just got edit as well, and took a read of the my stock PCM. I would be happy to email the read to you so you could go down the DTC list.
I have a 2000 M6 WS6</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I have a 2000 A4 WS6 so we are close. Thanks for the offer that would be great! I picked up the stock 2000 SS a4 file that ChrisB had on his site this morning. I’m at work now and don’t have the laptop here so I haven’t read them yet but I will when I get home.
BUT, just in case there are issues with that other file I have, it would be really great if you could send me your stock file. It would need to go to nscott@safco1.com
Thanks a TON <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> This would be very helpful. Please let me know when/if you are able to send it. TIA. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Aug 2, 2002 | 01:52 PM
NoGo's Avatar
You have mail (or should at least)
<img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Aug 2, 2002 | 02:55 PM
RPM WS6's Avatar
<strong>You have mail (or should at least)
<img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">NoGo...thanks a ton <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
I received the e-mail. I will toss it onto a disk and read it tonight.
Thanks again <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
