F.A.S.T. XFI opinions and info
Originally Posted by silkey
anyone try and tune the fast without the map sensor?do i really need it if its just n/a only?
Yes it is what is called Alpha-N management. It is based on throttle position and RPM. No manifold pressure sensing is necessary with this like you said on a NA application. It just can not be used on a force inducted engine with any amount of accuracy. More so when referring to a car with a turbocharger due to the fact that manifold pressure can drastically change with little or no change in throttle position. Also keep in mind that you will not have a VE and a Target A/F table. to work with anymore like in Speed Density mode. Alpha-N uses a pulse width table to fuel the motor with.
Chris Macellaro
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
my car is already a stand alone system, no factory computer, it uses a system that is older then me, accel gen 6
HAHAHAHA join the club lafn.... Where did you get your standalone harness to completely wire your Gen VI? And pardon me if I ask but if you have Gen VI why not just upgrade to Gen VII???? It has nitrous functions, will wire up to your opti and won't be a new learning curve to tune it since you already have Gen Vi???? just a question....
the stand alone harness came directly from accel and i heard bad things about the gen 7. but i will be running a large frame turbo set-up soon, i am just getting the car ready as much as possible so i don't have to change to much at one time, that causes issues most of the time.
