P0118=HIGH VOLTAGE ENGINE COOLANT SENSOR
Old Aug 3, 2002 | 02:20 PM
birdofprey's Avatar
Default P0118=HIGH VOLTAGE ENGINE COOLANT SENSOR
I have replaced the sensor 3 times now. I ATAP'ed it and it said that it was@-38 degrees. It makes the car idle weird and sometimes it will die. Any help would be greatly appreciated. <img border="0" alt="[Banging Head]" title="" src="graemlins/gr_banghead.gif" />
Old Aug 3, 2002 | 02:28 PM
BLOWNMERO's Avatar
Default Re: P0118=HIGH VOLTAGE ENGINE COOLANT SENSOR
maybe the wire is fried. Try it unplugged.. and see if you get the same results
Old Aug 3, 2002 | 05:13 PM
birdofprey's Avatar
If you had to rewire it would it be hard to and where wouldcould I get the wires?
